how to find the suitable IOS for cisco switches
Answered Question
Hi all,
can anyone help on this .I want to find out some advanced ios version link ssh,bgp and some features. where can i find that. if i logging into the software advisor it display as forbidden error. please solve this issue.
Thanks in advance
Gopianth.L
Correct Answer by Reza Sharifi about 7 years 8 months ago
Hi gopinath,
Use the feature navigator to help you determine the features you need.
Here is a link to it:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Reza
Overall Rating: 4.5 (2 ratings)
Lucien Avramov Thu, 10/29/2009 - 10:43
  • Red, 2250 points or more
For SSH you need a crypto image (k9).
You may want to go with enterprise with crypto or advanced ip services with crypto.
Look at the feature navigator as indicated earlier to clarify your doubts.
