Cisco PIX - ACL to permit range
Oct 29th, 2009
I have an old Cisco pix 515r v6.3
I need to permit a range of IP's to our mail server on port 25 (only this range should be able to access PORT 24 on the mail server). I'm not very familiar with the PIX, so any help with this would be appreciated. What would the command look like?
Thanks!
Collin Clark Thu, 10/29/2009 - 10:43
  • Purple, 4500 points or more
You can create an object-group.
object-group network permit_smtp
network-object host 1.1.1.1
network-object host 2.2.2.2
network-object 4.4.4.0 255.255.255.0
Then you apply the object group in the ACL.
access-list outside_access extended permit tcp object-group permit_smtp host [your host] eq 24
Hope that helps.
