Cannot access external webvpn
Oct 29th, 2009
Hello, I hope someone can help me. Users on the inside of a ASA 5510 cannot access an external webvpn site. I have allowed https on the outside interface as well as on the inside interface. Is there anything that I am missing? I have attached a portion of the logs.
hdashnau Sun, 11/01/2009 - 15:44
Your topology is unclear (ie is the external webvpn site on this ASA or on some other ASA or IOS router). If you only have one ASA, with webvpn enabled on the outside of this ASA and you are trying to access it from inside, this will not work (you would need to have webvpn enable on the inside interface as you wont be able to reach the webvpn on the outside interface from the inside).
orilsingh Mon, 11/02/2009 - 05:25
I apologise for not being clear. No, the webvnp is not on this ASA. It is hosted out on the internet (dont know what device) and the users on the inside LAN are trying to access it through this ASA.
Pravin Phadte Mon, 11/02/2009 - 04:27
you have allowed https for outside as well as inside.
Did you try for users inside the network to use the inside ip address to https ?
And for outside the network Oustde ip address of firewall .
It should work :)
Hope this helps
orilsingh Mon, 11/02/2009 - 05:33
I am not sure what you mean. I have https allowed on the inside interface for internal users going out to the internet and I have https allowed on the outside interface for external traffic coming into the private network. Would it be possible for you to point me in the direction of a example configuration?
your input is much appreciated, thanks.
