Unable to ping local interface. C3640 IOS v12.2
Oct 29th, 2009
I am having trouble seeing why I am unable to ping an interface that is local to the router while in an SSH session on the router. Although we are doing some policy based routing I can not figure out why I can not get a reply from the local interface. I do not see and traffic transverse the only connected firewall when I ping.
Here is the network portion of the config.
Network Config (Cisco IOS version 12.2)
interface FastEthernet0/0
description 4d-wifi-fa0.0
ip address 65.77.28.83 255.255.255.248 secondary
ip address 65.77.28.84 255.255.255.248 secondary
ip address 65.77.28.85 255.255.255.248 secondary
ip address 65.77.28.82 255.255.255.248
no ip proxy-arp
ip nat outside
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
interface FastEthernet0/1
description ATT-T1-inside
ip address 70.233.236.193 255.255.255.192
ip broadcast-address 70.233.236.255
no ip proxy-arp
ip nat inside
ip policy route-map outWifi
duplex auto
speed auto
interface Serial0/1
no ip address
no ip proxy-arp
encapsulation frame-relay IETF
no ip route-cache
no ip mroute-cache
frame-relay lmi-type ansi
interface Serial0/1.779 point-to-point
description ATT-T1-outside
bandwidth 1536
ip address 70.254.247.230 255.255.255.252
no ip route-cache
no ip mroute-cache
frame-relay interface-dlci 779
ip nat inside source static 70.233.236.218 65.77.28.85
ip nat inside source static 70.233.236.201 65.77.28.84
ip nat inside source static 70.233.236.200 65.77.28.83
ip nat inside source static 70.233.236.213 65.77.28.82
ip classless
ip route 0.0.0.0 0.0.0.0 70.254.247.229
no ip http server
access-list 1 permit 70.233.236.213
access-list 2 permit 70.233.236.200
access-list 3 permit 70.233.236.201
access-list 4 permit 70.233.236.218
access-list 5 permit 65.64.77.98
route-map outWifi permit 13
match ip address 1 2 3 4
set ip next-hop 65.77.28.81
PING Testing
okc-rtr-c3640#ping 65.77.28.81 source 70.233.236.193
Sending 5, 100-byte ICMP Echos to 65.77.28.81, timeout is 2 seconds:
Packet sent with a source address of 70.233.236.193
Success rate is 100 percent (5/5), round-trip min/avg/max = 12/18/44 ms
okc-rtr-c3640#ping 65.77.28.81 source FastEthernet 0/0
Packet sent with a source address of 65.77.28.82
Success rate is 0 percent (0/5)
okc-rtr-c3640#ping 65.77.28.82 source FastEthernet 0/0
Sending 5, 100-byte ICMP Echos to 65.77.28.82, timeout is 2 seconds:
Overall Rating: 0 (2 ratings)
Giuseppe Larosa Sun, 11/01/2009 - 01:40
  • Hall of Fame,
    Founding Member
Hello Jess,
what happens if you remove the line:
the ping results change?
Hope to help
Giuseppe
netjess Mon, 11/02/2009 - 08:21
Removing the NAT allows the ping. What I don't understand is why the NAT would affect the ping of a local interface. I also tried (from terminal session on the router) pinging 70.233.236.213 and that fails. pinging 65.77.28.82 from an outside source is successful.
