regarding 3750
Oct 29th, 2009
Hi All,
I have few questions regarding 3750.
1. what is throughput and backplane capacity of this switch.
2. Is there any difference in both the terms mentioned above or not.
3. Every one says through is being increased when we use stacking of switches but no one tell how and how much.
like if I have 3 switches and want to do stacking . Can someone show by calculating it here.
It is being asked in interviews also.
Please help !!!
Thanks.
glen.grant Thu, 10/29/2009 - 14:22
  • Purple, 4500 points or more
The 3750 has a 32 gbps backplane capacity for all 3 switches when using the stack cables and connected correctly. Just drill down on main cisco.com page under products and find the specs if you need more info.
sharma16031981 Thu, 10/29/2009 - 18:37
are these the same things.
what is the throughput of one switch.
thanks,
sharma16031981 Fri, 10/30/2009 - 15:17
Hello Leo,
This link show two columns switch performance mpps and switch fabric gbps so for 3750 TS it says 13,100,000 MPPS and 32 Gbps. So, how this information is related to my query ? please explain
Thanks !!!
