Configuring prefered BRI port for each phone ?
Oct 29th, 2009
I am looking for a way to configure a prefered BRI port for each phone. I have 2 BRI lines and I would like to have :
phone 1 calls always with BRI0
phone 2 calls always with BRI1
phone 3 calls always with BRI1
phone 4 calls always with BRI0, ...
Also I would like BRI0 outgoing call to show number 123456 and BRI1 outgoing call to show number 456789.
I feel like I have to use translation rules but I do not know how to make this config.
Thanks for your help,
Saurabh Verma Mon, 11/02/2009 - 07:36
Hi Stephane,
This level of customization is not supported through CCA. However, you could use COR-list to tie outgoing dial-peers to specific IP Phones. See if the thread below helps. If you don't have CLI expertise then this may be tough to do.
Similarly, the caller-id customization on a per port basis is not something that we can do today using CCA, but you should be able to configure outgoing dial-peers for specific BRI ports with required translations using CLI.
