testeven Thu, 10/29/2009 - 17:53
Hi!
Are you using Unity or Unity Express? In case you use CUE, please refer to the document below and check your configuration:
--> Configuring Voice-Mail Access
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/integration/unity_exp/configuration/guide/cue_cme1.html#wp1077388
Make sure you don't have a duplicated dial-peer with the same destination-pattern for the voicemail pilot number and verify that
the timeout for the CFNA on the phones is not equal to the hunt group timeout. The timeout for the CFNA should be greater than
Teresa.
If you find this post helpful, please rate! :)
