Problem with DBSpaceReclaimer on Solaris
Oct 29th, 2009
Good day.
We're trying to run the DBSpaceReclaimer procdure, but is failing. LMS is 3.2 running on Solaris 10. Herewith the command we're using and its output:
$ pwd
/opt/CSCOpx/lib/jre/bin
$ java -cp /Temp;/opt/CSCOpx/lib/classpath;/opt/CSCOpx/www/classpath;/opt/CSCOpx/MDC/Tomcat/webapps/rme/WEB-INF/classes/;/opt/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/lib/log4j.jar DBSpaceReclaimer
Usage: java [-options] class [args...]
(to execute a class)
etc...
ksh: /opt/CSCOpx/lib/classpath: cannot execute
ksh: /opt/CSCOpx/www/classpath: cannot execute
ksh: /opt/CSCOpx/MDC/Tomcat/webapps/rme/WEB-INF/classes/: not found
ksh: /opt/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/lib/log4j.jar: cannot execute
has anyone run this on Solaris successfully?
Many Thanks.
Joe Clarke Fri, 10/30/2009 - 01:07
You're trying to run it as if it were on Windows. Replace the ';' with ':'.
Joan Pelser Fri, 10/30/2009 - 04:21
Thanks Joe, im replying on Behalf of Pierre, who is currently in deepest darkest Africa :)
pvanvuuren Tue, 11/03/2009 - 23:01
Hi joe, different error message now, although i think we're getting closer.
/opt/CSCOpx/lib/jre/bin/java -classpath /tmp:/opt/CSCOpx/lib/classpath:/opt/CSCOpx/www/classpath:/opt/CSCOpx/MDC/Tomcat/web?apps/rme/WEB-INF/classes/:/opt/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/lib/log4j.jar DBSpaceReclaimer
Exception in thread "main" java.lang.NoClassDefFoundError: com/cisco/nm/rmeng/sa/db/RmeSaDbHandler
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:124)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:260)
at java.net.URLClassLoader.access$100(URLClassLoader.java:56)
at java.net.URLClassLoader$1.run(URLClassLoader.java:195)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:268)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319)
any advice?
Joe Clarke Tue, 11/03/2009 - 23:08
You have a capital 'T' in tomcat. That's wrong. You also appear to have a bad character in webapps.
