ASA VPN after PIX515 firewall no access
Oct 30th, 2009
Hello
I have PIX515 as internet gateway where I configured static NAT to ASA
static (inside,outside) "public IP" “ASA IP” netmask 255.255.255.255
On ASA VPN I set route outside 0.0.0.0 0.0.0.0 192.168.1.1 where 192.168.1.1 is PIX
With that configuration I'm not able to access ASA VPN or WebVPN from external host
BUT
On my network is another internet line (backup) and is based on Cisco 877
When i change gateway on asa to 192.168.1.254 (Cisco 877 backup gateway) and on that router will create NAT for port 443 or any other one and pointing to ASA IP then is working without any problems (problem is so that line is not performing as fast as PIX one )
Any Idea why PIX with static NAT not allowing accessing ASA while any other host is accessible on this NAT configuration on PIX Firewall
lgijssel Fri, 10/30/2009 - 01:34
  • Red, 2250 points or more
You must also add an acl permitting this traffic on the PIX:
access-list outside permit any host "public IP".
int outside
access-group outside in
regards,
Leo
cargiant1t Fri, 10/30/2009 - 02:34
Hi Leo
Thanks for your reply
At the moment i have about 7 static NAT and ACL running on that PIX and they are fine , but as son as I put ASA on that internal IP instead of www, pop or any other server , then is no response at all
cargiant1t Fri, 10/30/2009 - 03:25
I resolved that issue , it was problem on ISP site
