10-30-2009 02:07 AM - edited 03-11-2019 09:34 AM
Hi Champs,
I have configured timestamp logging on PIX 506E version 6.3(5). However the output of the log message does not give the timestamp. Let me know if i am missing out of anything. Thanks in advance.
show log
Syslog logging: enabled
Facility: 20
Timestamp logging: enabled
Standby logging: disabled
Console logging: disabled
Monitor logging: disabled
Buffer logging: level debugging, 49191709 messages logged
Trap logging: level informational, 40287472 messages logged
302013: Built outbound TCP connection 16430543 for outside:A.B.C.D/443 (A.B.C.D/443) to inside:172.16.150.99/46579 (A.B.C.D/46579)
302013: Built outbound TCP connection 16430544 for outside:A.B.C.D/443 (A.B.C.D/443) to inside:172.16.150.99/46580 (A.B.C.D/46580)
302013: Built outbound TCP connection 16430545 for outside:A.B.C.D/443 (A.B.C.D/443) to inside:172.16.150.99/46581 (v/46581)
Best Regards,
Manoj
10-30-2009 07:27 AM
Can you post your logging config?
service timestamps log datetime msec should enable time stamping
10-31-2009 05:35 AM
Hi Collin,
Thanks for the reply, however PIX does not seem to have this sort of command. Below is the output
PIXFW(config)# service timestamps log datetime msec
Usage: service {resetinbound|resetoutside}
PIXFW(Config)(config)#
We do have ASA in other locations, however with only "logging timestamp", it does show the timestamp in the logging. Any further thoughts on this? Thanks again.
Manoj
11-02-2009 06:21 AM
Manoj-
Sorry about that, I went into a router that I thought was a PIX. After looking in the command reference for 6.3, it states
Specify that syslog messages sent to the syslog server should have a time stamp value on each message.
Looks like you can't time stamp in the local buffer.
http://www.cisco.com/en/US/docs/security/pix/pix63/command/reference/gl.html#wp1028090
