GRE tunnel in cisco router
Laurent Aubert Fri, 10/30/2009 - 10:17
  • Cisco Employee,
It could many thing. For each side can you check the following:
1- PC can ping its local router
2- PC is using its local router as a default gw
3- Local router has a route in his RIB (static or dynamic) to join the remote LAN via the tunnel.
Laurent.
Laurent Aubert Mon, 11/02/2009 - 06:36
  • Cisco Employee,
Your config looks good but you need to check the configuration on the other side of the tunnel as well to be sure the routes are well configured as well.
Also be sure your PC use these routers as their Gw.
Laurent.
