Etherchannel interface traffic
Oct 30th, 2009
Dear All,
I have one 4507 switch configured with etherchannel in L2 mode. My PO interface is not showing inpute rate and output rate under the command show interface po50
Port-channel1 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 0014.xxx.xxx (bia 0014.a90b.c4ce)
Description: HLLSAP50
MTU 1500 bytes, BW 2000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is N/A
input flow-control is on, output flow-control is unsupported
Members in this channel: Gi5/47 Gi7/45
Last input never, output never, output hang never
Last clearing of "show interface" counters 1d00h
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
4396917200 packets input, 5411581491271 bytes, 0 no buffer
Received 72 broadcasts (0 multicasts)
1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored
1406549072 packets output, 231387068311 bytes, 0 underruns
0 lost carrier, 0 no carrier
where as member ports are showing traffic... Is it a normal behaviour and is it documented somewhere ?
glen.grant Fri, 10/30/2009 - 04:57
Look at the port channel interfaces themselves instead , thats where you will see how busy they are . You should some input rates on the interface though , I would say its not normal and possibly a cosmetic IOS bug. Does the channel look like its in the correct state when you issue the show ether summary command ?
