Network Downtime measuring with CW LMS 3.1
Oct 30th, 2009
We have a network of about 750 Devices. We have implemented LMS 3.1 as a primary NMS in our NW. Now we want to measure total downtime in a month through CW LMS. How to do that ?
Joe Clarke Fri, 10/30/2009 - 10:54
Really, there's no one report that gives you this. If you're using the Health and Utilization Monitor add-on, you can create pollers to monitor DEVICE availability. You can then run reports to see what the availability was over a given amount of time.
IPM can also do service-level availability tracking. That is, you can setup an IP SLA collector to monitor a given service on your network (e.g. an application server, host, etc.), then run reports to get that service's availability.
bhavyangs Fri, 10/30/2009 - 12:18
We have not purchased HUM. But IPM idea is good. We can config my all devices for some simple operation like echo & generate service availibility reports for all devices. right ? or there is a better way ?
