space.java.lang.OutOfMemoryError: java heap space
Answered Question
Oct 30th, 2009
I have a problem when i want to export the inventory via cwcli.
cwcli export inventory -u xxxx -p xxxx -m xxxx -device
Running LMS 3.2 on Solaris 10.
Actualy, there are 2000 devices.
I get this error (cli.log):
Java heap spacejava.lang.OutOfMemoryError: Java heap space
What do you think about ? Thanks for suggestions. Regards herve
Correct Answer by Joe Clarke about 7 years 2 months ago
This parameter controls the maximum amount of heap space the JVM will use. It has a default, and that's 512 MB. Large installations will require more memory.
Overall Rating: 5 (2 ratings)
Joe Clarke Fri, 10/30/2009 - 11:01
You can increase the allowed heap size by editing /opt/CSCOpx/MDc/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/cli/framework/heap.properties. Increase VM_HEAP_MAX from 512 to 1024.
hlichiere Fri, 10/30/2009 - 14:19
Thanks a lot for your help. This problem is solved. For my information, could you tell me what's this parameter and why there isn't the default. Regards
Correct Answer
Joe Clarke Fri, 10/30/2009 - 14:27
Patricia Oliveira Tue, 09/02/2014 - 13:56
Hi Joseph,
I'm having the same problem with CWLMS 4.0.1. But I didn't find this file heap.properties in the
Do you know where I customize this parameter in that version?
Patricia Oliveira
Joe Clarke Wed, 09/03/2014 - 23:11
There was a typo.  The directory is /opt/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/cli/framework/ .  This file should exist in LMS 4.0.1, thought that version is end of life.  You should really upgrade to 4.2.5.
