Warning message
glen.grant Fri, 10/30/2009 - 09:34
  • Purple, 4500 points or more
You have enough DRAM but not enough flash space to store the newer IOS . A lot of the newer 12.4 releases are bigger than 32 meg in size thus the requirement for 64 meg of flash. You would need to upgrade flash to a bigger size.
thotsaphon Fri, 10/30/2009 - 10:24
  • Gold, 750 points or more
Sergey,
The maximum for 2611XM is 256/48.
Check these link out:
http://www.cisco.com/en/US/prod/collateral/routers/ps259/product_data_sheet0900aecd800fa5be.html
http://www.cisco.com/en/US/docs/routers/access/2600/hardware/installation/notes/2600mem.html#wp93135
Edit: I'm not sure why the only IOS below needs 256/64. It might be wrong on the download page or the documents I provided are out of date. (grin)
INT VOICE/VIDEO, IPIP GW, TDMIP GW
c2600-ipvoice_ivs-mz.124-15.T10.bin
Release Date: 16/Sep/2009
Size: 25902.84 KB (26524500 bytes)
Minimum Memory: DRAM:256 MB Flash:64 MB
You will be fine with 256/48 if you are not a fan of IPIP GW. (J/K)
HTH,
Toshi
glen.grant Fri, 10/30/2009 - 11:43
If what you are saying is true then those "T" train images probably should not be under 2611XM . All the 2600XM boxes run the same images and say something like a 2651XM may have enough to run those . My advice would be to run a just the 12.4 mainline image in which case you have enough dram and flash for any image in the mainline train.
