CUCM 7.1.2 - AbbrDial Not Working
Oct 30th, 2009
Hello All,
We are trying to setup Abbreviated dialing. I have a user's phone and when they hit personal directory it goes right in.
When I'am on hook I dial 8 which coresponds to an abbreviated dial they set up in ccmuser, then I hit abbrdial but it gives me an error "number not configured". What could be the issue? It is a 7941, code is SCCP41.8-4-4S and I restarted the cisco call manager service, is there another service I might need to restart? Thanks
Jason
Overall Rating: 4 (1 ratings)
steigja Thu, 11/05/2009 - 07:10
Michael,
Here is a screen shot. I removed the last 7 digits of the numbers that start with 91732. So with this users phone when I dial 8 and abbrdial button it says number is not configure.
Jason
htluo Thu, 11/05/2009 - 13:14
  • Red, 2250 points or more
I see you have two abbr. dial numbers set up. Could you tell me what happened when you try to do abbr. dial?
An example would be like below:
1) The phone is on hook
2) I pressed 5. "AbbrDial" soft button shown up.
3) I pressed the "abbrDial" button.
4) I got the error "...."
Michael
steigja Wed, 11/11/2009 - 05:23
Yes Michael that is when the issue occurs, when I'am on hook and i dial 8 and then I hit abbreviated dial I get the error "number not configured"
andres.pasten Thu, 05/05/2011 - 14:41
I've the same issue with a CUCM 7.1(5b). I've tested this config on a CUCM 5.1(3) and it works.
Did you solve this issue?
TIA
Andres Pasten
Adexus S.A.
kleintz Wed, 11/04/2009 - 01:08
Hi Jason,
in my opinion, the key AbbrDial works only with the "normal" speed dials, which you can configure for the phone. If you use the personal directory, you have the possibility to use personal address book and fast dial, but fast dial not with the softkey AbbrDial. Try to configure a normal speeddial button and use the softkey.
Heiko
