Can you insert a Pause in a Speed Dial?
farrshepherd
I have a user that would like to program in their cell phone to their speed dial so they can check their voicemail. Is there a way they can insert a 3 second pause after the cell # on the speed dial so that they can follow their phone number by their password so it will go right in to their messages?
Saurabh Verma
Level 4
Level 4
There is a way to configure this using CLI (not supported in CCA). Configure the speed-dial with phone number. Create an outgoing pots dial-peer with specific match (destination-pattern = cell phone #). Then use the prefix command in the following format:
prefix 14085551111,,123
     where, "1" is the longdistance code, "4085551111" is the cell phone number, "," will insert the pauses that you are looking for and "123" is the password.
HTH,
Saurabh
