five 3750G stacked together, how cpu util calculated in show process cpu?
Oct 30th, 2009
Hi, very simple question:
I have 5 3750G stacked together. When I issue "show process cpu sorted" cli cmd, how the IOS calculates the CPU util for these 5 CPUs, average?
Thanks.
gy
thotsaphon Fri, 10/30/2009 - 11:11
  • Gold, 750 points or more
Gy,
It's not average. What you got from that command is the CPU utilization of the master switch. I used to think about this before. Many control-plane features are done on the master switch. Data plane/ forwarding plane features are done on the local switches. I would be great if they can share CPU resources between them. (grin)
HTH,
Toshi
Gongyuan Yao Fri, 10/30/2009 - 13:38
Hi Toshi,
Thank you so much. It is true. This only shows the master cpu. For other CPU util, we have to use:
>remote command X show process cpu
to get them.
Nice weekend.
gy
