2 circuits failover????
Oct 30th, 2009
Can you guys tell me what is the best way to set this up.
We have 2 circuits connected to our DMVPN router.
a) Primary circuit is used for DMVPN/internet browsing (38.99.x.x on port gi0/1)
b) secondary circuit will be used for internet browsing should primary goes down. (206.191.x.x on port fa0/0/0).
I am not sure how to configure it so when the primary fails the secondary circuit will allow internet browsing only.
I configured the tunnels etc to use the primary circuit.
Any suggestions?
thx
Giuseppe Larosa Sun, 11/01/2009 - 01:51
  • Hall of Fame,
    Founding Member
Hello Kimraj,
if the second circuit is not to be used to provide access to the intranet via a second DMVPN cloud; all you need is a floating static route that will not used until better (with lower AD) default routes exist either received in the DMVPN or pointing to primary circuit.
example:
ip route 0.0.0.0 0.0.0.0 206.191.x.y 201
this should be enough.
You probably need to configure NAT to provide internet access.
Hope to help
Giuseppe
ksohan4730 Mon, 11/02/2009 - 06:18
Thanks, i make the changes and try it out.
Much appreciated
