Hairpinning Fails
Oct 30th, 2009
I have two local subnets 192.168.1.0 and 192.168.2.0 behind another router. I hairpinning on the ASA (IP 192.168.1.252) to route traffic to the subnet 192.168.2.0.
I applied the next commands (I received help from pkampana to do this):
same-security-traffic permit intra-interface
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.2.0 255.255.255.0 192.168.1.0 255.255.255.0
route inside 192.168.2.0 255.255.255.0 192.168.1.254 1
If I ICMP echo using ASDM Packet Tracer works in both directions.
If I ping using a computer from subnet 192.168.1.0 to subnet 192.168.2.0 works.
If I ping using a computer from subnet 192.168.2.0 to subnet 192.168.1.0 fails.
If I remote desktop from any subnet fails and ASDM is logging the error that say:
severity: 6
Syslog ID: 106015
Source IP: 192.168.1.153
Destination IP: 192.168.2.4
Description: Deny TCP (no connection) from 192.168.1.153/1168 to 192.168.2.4/3389 flags RST on interface inside.
Thank you in advance.
RC
acomiskey Fri, 10/30/2009 - 11:43
  • Green, 3000 points or more
You could try this on the inside interface instead of your nat0 acl.
global (inside) 10 interface
nat (inside) 10 0 0
rafaelcervantes Tue, 11/03/2009 - 08:31
when i first try to run this command I received the error
Result of the command: "nat (inside) 10 0 0"
Duplicate NAT entry
That is because I already have the command nat (inside) 1 0.0.0.0 0.0.0.0.
I changed this one: nat (inside) 1 0.0.0.0 0.0.0.0
for this one: nat (inside) 1 192.168.1.0 255.255.255.0. and applied the one that you give to me: nat (inside) 10 0 0 and global (inside) 10 interface but still does not work.
Thank you.
RC
acomiskey Tue, 11/03/2009 - 08:56
Go back to your original way but remove one of these lines.
Nat exemption is bidirectional so 1 line should be all you need.
rafaelcervantes Wed, 11/04/2009 - 10:07
I already removed the line:
Still does not work.
The syslog explanation of the error is :
The security appliance discarded a TCP packet that has no associated connection in the security appliance connection table. The security appliance looks for a SYN flag in the packet, which indicates a request to establish a new connection. If the SYN flag is not set, and there is not an existing connection, the security appliance discards the packet.
Any help is greatly appreciated.
RC.
