HREAP option 'missing' on a thin AP1231G-E-K9 after conversion
Answered Question
Oct 30th, 2009
AP1231G-E-K9 was converted to a thin client AP to be managed on a controller.
After a 'succesfull' conversion, the AP did registered with the controller, but since it's located at a remote site, it was be be coverted run HREAP. The AP is connected on a port that is in a trunk port to carry multiple vlan so it can support multiple SSIDs, but for some reason, when you select the AP mode, the HREP option is not there.. Follow the same procedure to convert the others with no issue like this.. Under the IOS image of the AP ( as reported by the controller ) it reads correctly 12.4(18a)JA2
Correct Answer by dancampb about 7 years 2 months ago
Correct, H-REAP is not supported on the 16MB AP's.
Overall Rating: 5 (1 ratings)
John Cook Fri, 10/30/2009 - 12:18
I'm pretty sure that the 1231 isn't a HREAP supported AP. Someone please correct me if I'm wrong on that though.
Edit - from the WLC60 guide "Hybrid REAP is supported only on the 1130AG, 1140, 1240AG, 1250, and AP801 access points"
Correct Answer
dancampb Fri, 10/30/2009 - 12:27
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
