LMS 3.1 Baseline Template Fails
Oct 30th, 2009
NEED HELP! :-)
I made a baseline template that basicaly says: If you encounter an interface with a vlan24, apply a port-security mac-address sticky command. TEMPLATE FOLLOWS:
In Conditional Block's SUBMODE:
interface [#.*Ethernet.*#]
CLI Command (of conditional block is):
+ switchport access vlan [#(24)#]
Use the SubMode of above condition (yes)
CLI Command:
+ switchport port-security mac-address sticky
UNFORTUNATELY, THE MESSAGE I GET AFTER THE DIRECT DEPLOY IS:
*** Device Details for cdp-aa-sw-c02-02 ***
Protocol ==> Unknown / Not Applicable
Selected Protocols with order ==> SSH
Execution Result:
CM0150 Deploy Baseline template to PRIMARY config on device failed Cause: CM0070 Copy Config to device failed on cdp-aa-sw-c02-02 Cause: Action: Check device credentials and reachability.
CM0100 Copy PRIMARY Running Config to PRIMARY Startup Config on device not attempted
CM0089 Config archival successful for cdp-aa-sw-c02-02
Do you have a clue what is wrong with this immediate job deployment??? Can you help me fix it so it applies correctly!?
Thanx in advance,
WANimal
Joe Clarke Fri, 10/30/2009 - 14:26
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Post the job directory for this job. The directory is found under NMSROOT/files/rme/jobs/ArchiveMgmt on Windows and /var/adm/CSCOpx/files/rme/jobs/ArchiveMgmt on Solaris.
