UC/SAN Certificate on 11500
Answered Question
Oct 30th, 2009
Does anyone know if UC or SAN certificates are supported on the 11500? I've heard that wildcard certs can be used but those are a little different. Are they supported but you just can't create the CSR on the 11500 itself and need to import it along with the key from a different box?
Any help would be great.
Correct Answer by Gilles Dufour about 7 years 2 months ago
That's correct.
We should be able to handle the SAN certificate as we don't really do much with the certificate.
I just verified and it works fine.
Gilles.
Overall Rating: 5 (1 ratings)
Correct Answer
Gilles Dufour Mon, 11/02/2009 - 00:54
That's correct.
Gilles.
