%HSRP-4-DUPADDR : Duplicate address
Oct 30th, 2009
Hi, I have two 6509 switch and I have configured vlans on them having L2 trunk ports. I am getting error like
%HSRP-4-DUPADDR : Duplicate address [IP_address] on [chars], sourced by [enet]
Please suggest what to do and troubleshoot where is the duplicity?
Reza Sharifi Fri, 10/30/2009 - 19:38
  • Cisco Designated VIP,
    2017 LAN
Check the configurations on all the HSRP routers to ensure that the interface IP addresses are unique. Also check that no Layer-2 loops exist in your network.
Reza
Rupesh Kashyap Fri, 10/30/2009 - 20:09
I am not seeing STP loop in L2 network.
All HSRP vlan IP is unique. Please help as I am gettin the error for vlan---
329628: .Oct 30 18:12:52 PST: %IP-4-DUPADDR: Duplicate address 10.32.137.2 on Van137, sourced by 0017.5a18.034b
viyuan700 Fri, 10/30/2009 - 21:28
  • Silver, 250 points or more
check if u have the problem mentioned below
If static NAT is configured with the same IP on each router, the routers advertise each other with the MAC addresses, and the routers display the %IP-4-DUPADDR: Duplicate address [ip address] on [interface], sourced by [mac-address] error message. Refer to NAT-Static Mapping Support with HSRP for High Availability for more information.
see the link for more info
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_q_and_a_item09186a00800a9679.shtml
Rupesh Kashyap Fri, 10/30/2009 - 23:14
No NAT is configured, no loop in STP l2 domain, no duplicate IP. Is it possible, if we have same vlan IP on any other L3 domain in our datacenter & we are getting the alert. I mean, Can HSRP cross L3 boundary ?
Peter Paluch Sat, 10/31/2009 - 02:02
  • Cisco Employee,
Hi Rupesh,
Double check the HSRP configuration on both your switches once again. Often a small but significant issue is overlooked:
The "standby" command accepts a group number as the next parameter, for example,
standby 1 ip 10.32.137.2
Here, the standby group number will be 1. However, the group number may be omitted, resulting in a command
standby ip 10.32.137.2
In this case, the group number is 0.
Now, if two routers are configured for HSRP, one having the group number specified and the other not, actually two distinct standby groups are created inadvertently that indeed collide in their IP address. The solution here is simple: to make sure that the group number is the same, preferably by having it specified explicitly on all routers.
Best regards,
Peter
Giuseppe Larosa Sat, 10/31/2009 - 04:01
  • Hall of Fame,
    Founding Member
Hello Rupesh,
find device with MAC address 0017.5a18.034b
it is sourcing ip packets with
MAC SA = 0017.5a18.034b
IP SA = 10.32.137.2
the MAC OUI is Cisco so it is another device that is using 10.32.137.2 that is probably an IP address used in SVI vlan137 on complaining node.
I don't see HSRP related issue in this message.
my guess two devices have the same ip address in this vlan (may be the two HSRP members)
Hope to help
Giuseppe
