Route-refresh vs soft-reconfiguration inbound
Oct 31st, 2009
If IOS supports route-refresh capability then can i do away with soft-reconfiguration inbound to save memory and cpu utilization in multi-vrf ce routers.
Kas
Laurent Aubert Sun, 11/01/2009 - 09:02
  • Cisco Employee,
Absolutely !!
soft-reconfiguration inbound is more seen as a troubleshooting tool and should be enabled only to check what you are receiving and then should be removed.
Laurent.
