possibility/way to filter syslog-message on a c6500
Oct 31st, 2009
I have several (to much) Error-Messages of a c6500-linecard which is logging ~every second with serverity 2 to a external syslog server.
(it is planned to replace of the linecard in some days)
Is there any possibility/way to filter only these message so that this isn't send to the syslog / IOS: "logging server <IP>" ?
Message is:
%PM_SCP-SP-2-LCP_FW_ERR_INFORM: Module 2 is experiencing the following error: Port #1 transient TX Pb error.
Lucien Avramov Sat, 10/31/2009 - 09:55
Under IOS version "s72033-ipservicesk9-mz.122-18.SXF5.bin" with Error message as "%PM_SCP-SP-2-LCP_FW_ERR_INFORM: Module 4" when "sh int gig 2/1" issued in router mode with external port connected with GBIC(SC-SX)
The filtering can not be done on the switch, but maybe on your syslog analyser software.
However you may be experiencing cosmetic bug if you run SXF5 and an upgrade should get rid of this.
rnolden Sat, 10/31/2009 - 10:46
we have a actually IOS = 12.2(33)SXI and the error is since a blackout (power cut) yesterday at noon.
so after the unintended reboot of the hole infrastructure the diag of this Switchmodule isn't ok and this error is still present.
one more reboot hasn't solved the problem.
