Botched Password Recovery on ASA 505
Oct 31st, 2009
Hi all, I goofed on the ASA password recovery (
Now when I boot the ASA the firewall boots into rommon0
If I type boot it will load the default config, but not my original config that I performed the password reset on, which was successful.
From rommon0# (typing boot)
It boots to ciscoasa#
I can then "copy startup-config running-config"
Which brings me to my original config (with the enable password being reset)
Any ideas on how I can fix this?
Collin Clark Mon, 11/02/2009 - 07:58
My configuration register is set to 0x00000001
Once you boot into the OS, you can enter the value. Save the config and reboot.
ciscoasa(config)# config-register 0x00000001
This is from my lab box and it's a 5505. Yours may not be the same so try it at your own risk.
Hope it helps.
