Can we migrate to CUCM Business edition from CUCM 4.X, 5X and even 6.X?
Answered Question
Nov 1st, 2009
I am wondering because when you install CallManager Business Edition you get a prompt that states that you are running a BASIC setup installation and No DMA Data is requested, and refers you to a Cisco Link so you purchase the upgrade from a previous version and get another media to setup the BE installation.
Am i right? is this installation possible with another media? What would be the workaround for this.
Thanks in advance
Correct Answer by Rob Huffman about 7 years 6 months ago
Hi Carlos,
There is no migration path from Communications Manager (any version) to Cisco Unified Communications Manager Business Edition, so this is why you can't find the DMA info. That doesn't mean you can't go this route but you will have to re-build from scratch without the benefit of DMA (Data Migration Assistant).
Ordering Information
The Cisco Unified Communications Manager Business Edition offering is for new installations only. **There is no migration to or from the Cisco Unified Communications Manager Business Edition.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps7273/product_data_sheet0900aecd805e6985.html
Your IP Phone license DLU's are able to be migrated with the help of;
[email protected]
They will send you a spreadsheet like the one attached below so you can fill in your current phone types/numbers and a new DLU License will be created for you. This way your investment is carried over to CUCM-BE.
Hope this helps!
Rob
Overall Rating: 5 (2 ratings)
Correct Answer
Rob Huffman Sun, 11/01/2009 - 04:23
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Carlos,
[email protected]
Hope this helps!
Rob
