[solved] SRW224g4 show mac-address ?
thomastoka
cant find the function to show the ports mac-addresses?
The switch itself is not problem, also the arp table, but in the arp table are only ports the had a ping to the switch.
Thank you.
Edit: Solved myself:
It works with lcli ;-)
telnet to your switch
login
hit CTRL-Z
type lcli
login
show bridge address-table
chrcoope
Thomas,
Nice work! This can also be seen on the web interface under the admin tab, dynamic address.
Christopher
Webview is broken in the recent firmware 1.2.2b :-)
chrcoope
Thomas,
I login with admin no password on 1.2.2b and it works fine. For IE browsers, have you tried this:
Open regedit and navigate to:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\InternetSettings
Look for two keys:  MaxConnectionsPerServer and MaxConnectionsPer1_0Server.
If these keys(DWORD) do not exist, you will need to create them.
Edit these keys and check the Value Data to 2 in decimal.
Christopher
only ie6 works with ie4linux :-)
but at this moment i am talking to the hotline about this case, cause besides of the browser issue it (webview) is now not reachable at all!
