site to site VPN using PIX-515E and no VAC card?
Nov 1st, 2009
I'm considering using an existing PIX-515E as one end of a site to site VPN, but can't find any stats for how many Mbps of throughput the unit with no VAC or VAC+ card will handle.
Would it handle up to 10Mbps of 256 bit AES IPSEC VPN traffic?
Patrick0711 Sun, 11/01/2009 - 12:03
You will likely only see a few Mbps of VPN traffic, especially with AES-256. There's a night and day difference between using the VAC card and offloading the encryption processes to the PIX CPU.
I would suggest using a more efficient encryption algorithm like AES-128 and SHA1.
Farrukh Haroon Mon, 11/02/2009 - 11:08
The throughput is mentioned on this link:
Performance Summary
• Cleartext throughput: Up to 190 Mbps
• Concurrent connections: 130,000
• 168-bit 3DES IPSec VPN throughput: Up to 135 Mbps with VAC+ or 63 Mbps with VAC
• 128-bit AES IPSec VPN throughput: Up to 130 Mbps with VAC+
• 256-bit AES IPSec VPN throughput: Up to 130 Mbps with VAC+
• Simultaneous VPN tunnels: 2000
Please rate if helpful, Regards
