show ip interface brief command output
Nov 1st, 2009
I have seen 'show ip interface brief' command output.
For some interfaces 'method' it is showing 'NVRAM' and for some interfaces it is 'Manual'.
What does it mean?
SKR
Overall Rating: 4.5 (2 ratings)
Joe Clarke Sun, 11/01/2009 - 09:49
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
NVRAM means that the interface was configured via the startup configuration at boot time. Manual means the interface was configured manually after boot time.
sivakondalarao Sun, 11/01/2009 - 15:33
Hi jclarke,
Thanks for your response. So, if I reload the router it shows 'Method' NVRAM right?
SKR
Joe Clarke Sun, 11/01/2009 - 15:40
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, provided you don't do any configuration after that (and you've saved some interface config to the startup config).
dsafwan01 Mon, 06/02/2014 - 06:59
hello,
what about CONFIG method. what is the difference between that and manual and how can I change it to CONFIG? this is related to the ASA 5585.
thanks!!
Joe Clarke Tue, 06/03/2014 - 07:56
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please start a new thread for your question.  You'll likely want to ask in one of the security spaces to get the ASA experts.
