SSL VPN and Snow Leopard
timothybward
Anyone here experiencing problems with SSL VPN Split Tunneling and OS X 10.6? I'm using 2.4 and it works flawlessly on my Windows 7 clients but on OS X I've only got access to tunnel hosts and nothing on the internet.
Any ideas?
tim
hdashnau
Tim,
Check to see if you can access the internet by IP address instead of hostname -- this would indicate a DNS issue. If its a DNS issue check the group-policy that you connect to for if split-dns is defined. If theres no split-dns defined, add it:
1. Have the user connect in and grab "show vpn-sessiondb svc" to see which group policy is being used
2. Go to that group-policy and make sure you have "split-dns value "
-heather
Thanks for the response -- I will look into this soon. Any idea why it would work flawlessly with Windows?
Thanks!
Tim
