Upgrading 3825 Router flash
Nov 1st, 2009
I am upgrading a 3800 series router and I need to backup the flash card and install a new one in its place. What is the command to backup the card onto my computer via tftp and then what is the procedure for putting the information on the new card when I will be in rommon mode. Thank you in advance.
Leo Laohoo Sun, 11/01/2009 - 17:21
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
copy flash:. tftp:
winslowtravis Sun, 11/01/2009 - 18:31
is the command the same for putting it back on the new card when i have a blank flash? sorry if i was not clear, i am more concerned with loading everything back onto the new card when i will be in rommon mode. also do i need to format the new card or is it ready to go from cisco?
Leo Laohoo Sun, 11/01/2009 - 19:51
  • Hall of Fame,
    2017 LAN, Wireless
Yes. I can save you some time if you have a USB thumb drive (<2Gb size).
What you do is insert the USB into anyone of the two USB slots of the router. Format the USB stick (this is important) using the command format usbflash0:. Once this is done, copy all files from your flash drive to the USB thumb drive using the command copy flash:. usbflash0:.
Hope this helps.
winslowtravis Sun, 11/01/2009 - 20:12
thanks for the tip. what is the proper method to copy from the usbflash to the new rom card?
copy usbflash0: slot0:
thank you for your reponses
