CallerID question for PRI with Uc520
Nov 1st, 2009
I have a UC520.  I have 10 DIDs going out with 10 phones.  I'm confused with the callerID aspect.  2 of the phones when calling to my cellphone show the entire number (503) XXX-1400.  The rest of the phones when calling out show a caller id of only 4 digits ((1)401) which is the extension calling out from.  How can I make all Calls from all phones show the full phone number?  Each phone number is 503xxx1400 (calling from extension 1400) and 503xxx1401 (calling from extension 1401 etc...)  (last 4 of phone number is the extension in every case.)  Is there anyway to program this from the CCA?  Im no good at command line.
Basically I want to set caller Id to from each extension 1400-1409 to the related phone numbers 503xxx1400-503xxx1409.
Saurabh Verma Mon, 11/02/2009 - 07:50
  • Silver, 250 points or more
Yes, this should be configurable through CCA. In theConfigure > Telephony > Dial Plan > Outgoing, there is an option for caller-id. Look through that configuration. You should have a range for internal extension and DID mapping. Post your configuration and CCA screen captures.
-Saurabh
