How to get I/O memory statistics of lan switches and routers via snmp
Nov 2nd, 2009
we want to observe the memory utilization of several switches and routers in cacti. While implementing the OIDs of process and I/O memory in cacti we found out that especially the I/O memory is placed in different memory instances on different switches/routers.
Does anybody know the reason for this differences and if there is any documentation about using memory instances for I/O on the different switch and router models?
We also saw two 7206 routers running different feature sets using different memory instances:
Router 1: Processor(1), I/O(2), Transient(11)
Router 2: Processor(1), I/O(3)
Many thanks in advance,
Thorsten
Joe Clarke Mon, 11/02/2009 - 09:07
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The dynamic pool type is set depending on the architecture. Some devices use PCI memory for I/O while others have a specific I/O pool. You will always see the same type of pools on the same platforms. Therefore, you will have to create separate cacti templates for each platform type to monitor all memory pools.
thorsten.steffen Mon, 11/02/2009 - 23:30
If on same platforms same pool types are used do you know the reason why two 7206VXR with different IOS feature sets use different memory pools?
7206VXR router 1 (Advanced IP Services): Processor(1), I/O(2), Transient(11)
7206VXR router 2 (Service Provider 3DES): Processor(1), I/O(3)
Joe Clarke Mon, 11/02/2009 - 23:34
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There must be different hardware in these two 7206s. What are the NPE/NSE models in each?
thorsten.steffen Wed, 11/04/2009 - 00:06
You are correct.
One is a 7204VXR, the second a 7206VXR.
May this be the reason for the different memory pools?
Both use a NPE-G2.
Joe Clarke Wed, 11/04/2009 - 09:41
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, different models, and different processing hardware may contain different pools.
