thotsaphon Mon, 11/02/2009 - 03:13
Kuppannagar,
As per your question,G means all ports are Gigabitport.
HTH,
Toshi
Jagdeep Gambhir Mon, 11/02/2009 - 06:01
Right, the only difference between the Cat 3750 and the Cat 3750G platforms is that there are more port ASICs on the G platform.
~JG
Do rate helpful posts
Joseph W. Doherty Mon, 11/02/2009 - 09:29
Another difference, the "G" (gig) suffix 3750 switches might have insufficient fabric bandwidth and/or PPS performance to support all ports running concurrently at wire-speed.
