Removing Subscribers from Unirt with no AD Account
Nov 2nd, 2009
We have a problem whereby several users were removed from AD before they were removed from Unity (Ver 4.x)As a consequence we cannot now delete these users from Unity. Does anyone know of a method to do this.
cheers
Bradford Magnani Mon, 11/02/2009 - 07:32
  • Cisco Employee,
Mark,
Chances are they're now going to need to be manually deleted from SQL. If you feel comfortable doing this, the Subscriber table in Enterprise Manager contains all of the subscribers. Find the affected users and delete their entire row.
Otherwise, I would suggest opening a TAC case if you're not comfortable with performing this.
Hope that helps,
Brad
Tray Stoutmeyer Mon, 11/02/2009 - 09:19
  • Cisco Employee,
Have you tried the remove subscriber properties tool? I would think that would work. You can access the tool from /Commserver/Utilities/RemoveSubscriberProperties.
Load the tool and look for the user that you need to remove. It should have a bunny icon next to it. Remove that one by righ-clicking and choosing remove.
Hope this helps!
Tray
