Group policies/customization
Hi!
I've run into a problem regarding Clientless SSL VPN. What i would like to do is to create a custom portal that the user will be directed to after successful login. I need to be able to tailor the portal depending on logged on user, i.e. user A should see his user specific information only, user B should see something else. My problem is that i can't find a way to see who's currently logged on. Is there any property that can be read via javascript?
Any ideas?
/Johan
Overall Rating: 4 (1 ratings)
Thanks! That's sort of what i'm looking for, although it might raise a problem. Lets say user A sign on using his credentials, but accidently selects user B's profile.
We want to use VPN to give our customers access to certain applications. One user may have access to 10 applications, another user will only have access to 3.
Is there any way to tie their username to a certain profile?
