CW 3.2 - RME Inventory Collection Failed
Nov 2nd, 2009
We have migrated the supervisor card from III to SUP 720 on Cisco 6509.
I get this error from Inventory Collection :
RICS0001: Internal Error,unable to process the collected data from the device.
Normally, this change should be detected and the inventory updated. Any suggestion ?? Regards.
Farrukh Haroon Mon, 11/02/2009 - 11:05
  • Red, 2250 points or more
Are your "Device Packages" updated for RME?
Go the Common Services >> Software Upgrade >> Device Upgrade and get the latest RME device packages (at least for the catalyst platform).
Or if possible, delete and re-add the device!
Farrukh
hlichiere Fri, 11/06/2009 - 12:44
All packages were applied. It seems RME is working fine since it was upgraded to 4.3.1. The swapped device appeared like "conflicting device". Regards
Farrukh Haroon Fri, 11/06/2009 - 12:45
Ok thats great news :)
Thanks for the update.
Farrukh
hlichiere Fri, 11/06/2009 - 14:34
sincerely, i don't know if this issue was solved applying the last RME update or applying the last device package according with RME 4.3.1. New swapp, not necessary about 6500, were planned. I keep you informed.
