Adding AV/AS Rule for AVG 9
Nov 2nd, 2009
A while back I had TAC send me instructions for adding custom AV rule for AVG 8. I seem to have misplaced those (they're not lost - I just can't find em). Can someone post the steps that I will need to add AVG 9 as a custom rule for NAC? Thanks in advance.
nagel Tue, 11/03/2009 - 12:56
OK...This what you need to manually add the rules for AVG 9
If you just want to allow them if Avg9 is installed you can create a new registry check.
Device Management -> Clean Access -> Clean Access Agent -> Rules -> New Check.
Check Category: Registry Check
Check Type: Registry Key
Registry Key: HKLM : SOFTWARE\Avg\Avg9
Operator: exists
Choose your Operating Systems
Check the box to create a rule based on the new check.
Under your existing AV Requirement the new rule should now
show up under Requirement-Rules.
In order to check the AV Definitions as being current we can add :
Check Category: File Check
Check Type: File Date
File Path: SYSTEM_DRIVE : \Program Files\Avg\Avg9\sc.dat
Operator: later than
File Date: Cam date - 5 days
File Date Type: Modification date
Select Your OS' and Automatically create a rule based on the check.
Add this check to your existing AV definition requirement rules and make sure you have
"Any Select Rule Succeeds chosen.
