DMVPN ISAKMP phase 2 SA policy not acceptable!
gustavo-salazar
Hi everyone,
I'm having toruble with a basic configuration DMVPN. In the debugging I can see how ISAKMP phase 1 completes, but them the phase 2 proposal fails. It says something about a cryptomap that doesnt exists. I thought that with these configuration I didn't need a cryptomap. The routers configuration and the debug print screen are attached. Any help would be aprreciated.
Gustavo
Herbert Baerten
Try this:
crypto ipsec transform-set medium esp-3des esp-md5-hmac
mode transport
Also, since both the spoke and the hub are behind NAT you'll need NAT-T, so definitely don't disable it.
17 Replies 17
gustavo-salazar
I tried the command show crypto map in the hub router and the spoke, and I can see what the error message is refered to.
Here's what the Hub router shows:
RPrueba2#sh cryp map
Crypto Map "Tunnel0-head-0" 65536 ipsec-isakmp
Profile name: medium
Security association lifetime: 4608000 kilobytes/3600 seconds
PFS (Y/N): N
Transform sets={
medium,
Interfaces using crypto map Tunnel0-head-0:
Tunnel0
And here's what the Spoke router shows:
PFS (Y/N): N
Transform sets={
medium,
Crypto Map "Tunnel0-head-0" 65537 ipsec-isakmp
Map is a PROFILE INSTANCE.
Peer = 64.116.129.158
Extended IP access list
access-list permit gre host 190.201.x.x host 64.116.x.x
Current peer: 64.116.x.x
PFS (Y/N): N
Transform sets={
medium,
Tunnel0
I don't know why the crypto map doesn't shows up in the Hub router. Any thoughts???
Gustavo
sdoremus33
Level 3
Level 3
When you defined the dynamic crypto map, did you integrate this into the static map. Ex:
Step2: Define transform set
Step2: Define the dynamic map
Step 3 integrate the dynamic map into the static map.
Also the dynamic map should have the transform set attributes only!!!
One other question in your MGRE config your network is between HUB and Spk1 , Spk2 correct, one other thing I did notice was your ip nhrp network-id for Spk(2) was set to 50, where the Hub is set for 100 and the other Hub router is set to 200, something to inverstigate further. HTH
sdoremus33
Level 3
Level 3
Spoke router
ip nhrp network-id 50
Hub router
ip nhrp network-id 100
So I changed the network ID numbers to 50. Still doesn't comes up.
Now I got a question. I don't know if you notice but I have a Firewall in the middle doing NAT. In the show crypto map in the Spoke, it says: access-list 103 permit gre host 190.201.x.x host 64.116.x.x. But as you can see int thu hub's FE 0/1 config I have a private IP address 172.16.x.x. So the crypto map is telling me that the tunnel is going to end up on the fireall interface or in the router interface behind the firewall? The NAT process is capable of doing that?
The configuration looks good, however I would try one another command on the spoke router
Set security associateion level per-host.
This command is used so thst the IP source in the spokes IPSEC proxy will be the spokes current physical /32 address, withtout this commaand would rather just use the ANY as destination in the ACL, which would preclude any other spoke router from setting up a physical map connection to the Hub router.
Just a thought. HTH
This command is use in global configuration on the spoke routers.
For the following statement: But as you can see int thu hub's FE 0/1 config I have a private IP address 172.16.x.x. So the crypto map is telling me that the tunnel is going to end up on the fireall interface or in the router interface behind the firewall? The NAT process is capable of doing that?
Also for testing purposes try adding the crypto-map to the outsied facing public interface on the spoke router. (For testing purposes)
sdoremus33
Level 3
Level 3
Just curious what are trhe outputs from the following commands
IPSEC Commands
sh crypto isakmp sa
sh crypto ipsec sa
sh crypto engine connections active
NHS Commands
sh ip nhrp
This could help us out further along with this problem.
sdoremus33
Level 3
Level 3
This looks like an issue with NAT primarily with the dst @172.x.x.x.
One thing you could also try for troubleshooting is use the following oommand to bypass ACL over IPSEC connections
Sysopt connection permit-ipsec
Sysopt connection permit vpn
Usage: sysopt connection permit-vpn
For traffic that enters the security appliance through a VPN tunnel and is then decrypted, use the sysopt connection permit-vpn command in global configuration mode to allow the traffic to bypass interface access lists. Group policy and per-user authorization access lists still apply to the traffic. To disable this feature, use the no form of this command.
I hope some of these issues help you out as I am running into a very similiaer situation .
I notice in looking at the logfs perhaps bypassing ACL NAT could point us in right direction.
Take care
*Oct 30 20:17:05.639: CryptoEngine0: validate proposal request
*Oct 30 20:17:05.639: map_db_find_best did not find matching map
*Oct 30 20:17:05.639: IPSEC(validate_transform_proposal): no IPSEC cryptomap exists for local address 172.16.x.x
*Oct 30 20:17:05.639: ISAKMP:(0:4:SW:1): IPSec policy invalidated proposal
*Oct 30 20:17:05.639: ISAKMP:(0:4:SW:1): phase 2 SA policy not acceptable! (local 172.16.x.x remote 190.201.x.x)
*Oct 30 20:17:05.639: ISAKMP: set new node 457288976 to QM_IDLE
*Oct 30 20:17:05.639: CryptoEngine0: generate hmac context for conn id 4
*Oct 30 20:17:05.639: ISAKMP:(0:4:SW:1):Sending NOTIFY PROPOSAL_NOT_CHOSEN protocol 3
sdoremus33
Level 3
Level 3
Another troubleshooting ides is to turn off Nat-T
no crypto isakmp nat-traversal
See what happens question do both devices support NAT-T, and keeaplives
One last ides for troubleshooting as I mentioned earlier you can try to add the dynaimc crypto map to the outside interface
Herbert Baerten
Try this:
mode transport
I forgot to mention: you'll need to configure transport mode on both the hub and the spoke.
