VPN with Fios and 2811 and ASA 5510
Nov 2nd, 2009
Hello All,
I have never configured a site to site vpn tunnel with a Cisco router. I have done plenty with pix to pix but never a Cisco router. I am hoping for a little direction.
We have a site that just got Verizon Business grade Fios. I am a little confused on how I would set this up. It was suggested in another post that I would connect a cable from the Fa0/0 on thr 2811 to one of the switchports of the FIOS router...is this correct? What ip would I assisgn the Fa0/0? And then I assume the Fa0/1 would have an ip address of the internal lan?
Can someone post any sort of example of how the config would look on the 2811?
Thank you so much for any help or guidance you can provide.
Patrick
