spa962, rss and cyrillic fonts
Nov 2nd, 2009
At our company we are trying to make a Linksys SPA962 phone use RSS in
Bulgarian (cyrillic). We installed the latest software (version 6.1.5a) and
the dictionary file bgS_v615.xml, but still all we get on the display is
garbage text. It looks like an encoding problem, but we had no luck
changing the encoding settings to all possible options. Here is a snapshot
of what we get...
We are out of ideas. Anyone there having the same isuue?
Patrick Born Mon, 11/02/2009 - 18:19
  • Cisco Employee,
Hi ipltdbulgaria,
Are the rest of the phone's prompts correct for the localization?
I'm trying to understand if the problem is with the dictionary file or with the RSS feed.
I do know that there are different types of RSS feeds and not all are compatible with the SPA phones.
Patrick
ipltdbulgaria Mon, 11/02/2009 - 23:39
Hi, Patrick
The rest of the phones are absolutely the same. We tried different RSS but still the same. Actually everythingelse with the localization works great, exept rss.
Patrick Born Tue, 11/03/2009 - 14:00
  • Cisco Employee,
Hi ipltdbulgaria,
I've requested the help of Engineering on this.
Patrick
Patrick Born Tue, 11/03/2009 - 14:02
  • Cisco Employee,
Hi ipltdbulgaria,
Can you please provide an example URL for the Eng team to view?
Patrick
jlai2 Tue, 11/03/2009 - 16:03
Hi ipltdbulgaria,
Can you provide me an example rss url to try?
John
Patrick Born Thu, 11/05/2009 - 14:53
  • Cisco Employee,
Hi ipltdbulgaria,
Initial analysis shows that we appear to be ignoring the charset in the HTML header. I've alerted the Product Manager and will report back.
Patrick
Patrick Born Mon, 11/09/2009 - 16:26
  • Cisco Employee,
Hi ipltdbulgaria,
I have heard back from Product Management. There are no engineering resources scheduled to enable Cyrillic RSS support in the SPA9xx IP phones.
This will be supported and working in the SPA500 IP phone family.
Patrick
ChrisCogdon Fri, 11/27/2009 - 19:46
I think patrick is saying that "we wont fix this problem for your SPA9xx phone, sorry".
As a workaround, you might be able to write a "gateway" for your RSS feed that translates the feed from UTF-8 into a character set the phone supports OR, force the character set encoding into the HTTP headers (as far as I can see, its only in the XML header)
Ie, if you wrote a proxy that just added Content-Type: text/xml; encoding="utf-8" to the headers, you might get it working. as far as I can tell, the feeds only put the encoding into the xml attribute.
