Site to Site VPN ASA 5510
Nov 2nd, 2009
Hello, hopefully someone can help me out with this. I'm CCNA level, but not very familiar with Site-to-Site VPN setup. I have an ASA5510 for a remote site and trying to connect to a 5520 at the main site. I am not seeing the tunnel come up at all. here is the main site config that is relevant to VPN:
interface GigabitEthernet0/0
description Trusted Internal Interface
speed 1000
duplex full
nameif inside
security-level 100
ip address x.x.x.x
interface GigabitEthernet0/3.10
description Time Warner External Interface
vlan 10
nameif TimeWarner
security-level 0
ip address y.y.y.y
access-list MATCH extended permit ip x.x.x.x [remote network]
nat (inside) 0 access-list MATCH
service resetoutside
crypto ipsec transform-set asa2transform esp-3des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map IPSECMAP 100 match address MATCH
crypto map IPSECMAP 100 set peer [remote outside interface]
crypto map IPSECMAP 100 set transform-set asa2transform
crypto map IPSECMAP interface TimeWarner
crypto isakmp identity address
crypto isakmp enable TimeWarner
crypto isakmp policy 100
authentication pre-share
encryption aes
hash md5
group 2
lifetime 86400
tunnel-group [tunnel name] type ipsec-l2l
tunnel-group [tunnel name] ipsec-attributes
pre-shared-key *
no tunnel-group-map enable ou
I have a few outside connections running into a switch and a trunk runnning into the ASA. I also have interface tracking for interface failover and the unit is a part of an active/standby cluster.
The config on the 5510 is the same except for the peer being the outside interface of the 5520 and the access-list being reversed.
Any help for a VPN newb would be much appreciated.
Farrukh Haroon Mon, 11/02/2009 - 20:20
Please post the output of the following:
debug crypto isakmp 127
debug crypto ipsec 127
debug crypto engine
moorelock Tue, 11/03/2009 - 08:28
x.x.x.x is the ip of the remote peer. I did the same on the remote peer and the address of the main site peer is in there, but all other output looks about the same.
I've attached the actual output with IPs removed.
moorelock Tue, 11/03/2009 - 08:30
Forgot to say thank you for the troubleshooting link. I did go through those steps and some points were very helpful in adding to my understanding of the VPN tunnel process. Unfortunately after going through the steps I am still having issues.
Farrukh Haroon Tue, 11/03/2009 - 10:55
Although the debugs are not so clear, it seems you either have a pre-shared key mismatch or a phase 2 parameter mismatch (transform-set, SA timer or crypto ACL).
I would do the following:
> Enter the pre-shared key again (making sure there are no ' ' spaces at the end (Altough this is highly unlikely with the ASA tunnel-group syntax)
> Remove the security association timers, setting them to their defaults (please remove from both sides)
> Re-Check the crypto ACL again, especially the subnet mask, they should be exact mirrors of each other
> Try using another phase 2 transform set (perhaps SHA+3des)
Please clear the existing sessions if any from both side before trying again. Also if possible, please post the output of both sides.
