Collin Clark Mon, 11/02/2009 - 12:47
  • Purple, 4500 points or more
Yes they are in the same Feature Set ( Advanced Security) and they can be independent of one another.
tech_trac Mon, 11/02/2009 - 12:50
So does it mean that it is one as a product (advanced security feature set) but different as functionality.
Secondly, is it necessary to install the IPS module (NME-IPS) in ISR Router to activate the IOS IPS features.
Collin Clark Mon, 11/02/2009 - 12:53
Yes, when you buy the feature set you get the ability to run both. You do not the IPS module, however running IPS in IOS only, you may only have a subset of signatures (depending on your RAM & flash). Also offloading to the module will save resources on the router. IPS is pretty demanding when running in IOS only.
