QoS trouble with class-map
Answered Question
Nov 2nd, 2009
I'm having trouble getting QoS to work on my router. I'm trying to get traffic from one specific address to be put in the priority queue. I will eventually fine tune this to specific ports but can't understand why this does not work. It does not match against the access list when I specify the address (192.168.1.15) but when match against any it matches meaning that it checks the access list but not working the way I expect it to.
boot system flash:c2600-ik9o3s3-mz.123-26.bin
no aaa new-model
ip subnet-zero
no ip source-route
ip flow-cache timeout active 1
ip cef
ip dhcp excluded-address 192.168.1.0 192.168.1.149
ip dhcp excluded-address 192.168.1.200 192.168.1.255
ip dhcp ping timeout 1000
ip dhcp pool Home
network 192.168.1.0 255.255.255.0
dns-server 4.2.2.2 4.2.2.3
default-router 192.168.1.251
lease 14
no ip bootp server
ip audit po max-events 100
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
class-map match-all TEST
match access-group name TEST
policy-map TEST
class TEST
priority 512
class class-default
fair-queue
interface Ethernet0/0
description Uplink to WAN
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no ip mroute-cache
full-duplex
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Ethernet0/1
description Uplink to LAN
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no ip mroute-cache
full-duplex
interface Ethernet0/1.1
description Default VLAN
encapsulation dot1Q 1 native
interface Ethernet0/1.100
description Home VLAN
encapsulation dot1Q 100
ip address 192.168.1.251 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip nbar protocol-discovery
no ip mroute-cache
interface Dialer1
description ADSL WAN Dialer
mtu 1492
bandwidth 768000
ip address negotiated
no ip unreachables
ip nat outside
ip flow ingress
encapsulation ppp
ip tcp adjust-mss 1452
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname [email protected] ppp chap password 7 *
ppp pap sent-username [email protected] password 7 *
ppp ipcp dns request
ppp ipcp address accept
service-policy output TEST
ip nat inside source list 10 interface Dialer1 overload
no ip http server
no ip http secure-server
ip classless
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list standard TEST
permit host 192.168.1.15
dialer-list 1 protocol ip permit
Correct Answer by mlund about 7 years 3 months ago
You are trying to match 192.168.1.15. This ip is on the inside. Maybe the router does nat before service-policy, then the match must be on the natted address.
You can try to set the policy on inside and set a dscp value. Then match the dscp value on outside.
example
policy-map inside
class TEST
set dscp ef
class-map match-all OUT
match dscp ef
policy-map outside
class OUT
priority 512
interface ethernet0/1.100
service-policy in TEST
interface dialer1
service-policy out OUT
/Mikael
Overall Rating: 5 (1 ratings)
Gregory Camp Mon, 11/02/2009 - 16:27
Try using an extended ACL instead
ip access-list extended TEST
permit host 192.168.1.15 any
johnyarborough Mon, 11/02/2009 - 16:32
Thanks for the reply. I have tried an extended ACL, and also with numbers instead of names and no change. I've also tried between match-any and match-all. I have also tried applying the service-policy to the Ethernet0/0 interface and see the same results. Is there a way to debug class-maps or access-lists to see what address it is trying to match against?
Correct Answer
mlund Wed, 11/04/2009 - 02:18
example
policy-map inside
class TEST
set dscp ef
match dscp ef
policy-map outside
class OUT
priority 512
interface dialer1
/Mikael
thotsaphon Wed, 11/04/2009 - 03:17
MiKael is right. Nat is done before doing queueing policies. What he has provided is a good solution.
HTH,
Toshi
