is a fractional T1-CAS with MGCP supported in call manager?
Hello all,
I have a customer that has a fractional t1, not a pri and we are moving it over to a 2821 router. We want to use MGCP
I have a tac case open, the engineer first said it wasn't supported but then realized i was refering to a t-1 cas. He then said it was supported and gave me a link (to version 3) we are on version 6.1.2
I configured it on the call manager. After i configure the ports however a link to ADD a DN shows up next to each port. Am i experiencing a bug? or do i need to assign a DN to each T1-CAS port?
that doesn't seem right.
any help would be great
I think i might be running into a bug.
When i add the t1-cas and the ports it has a link to ADD-DN next to each port.
They are running cm
however if i add the same gateway on another call manager (at another customer site) running it does not have the ADD-DN link next to the ports.
think its a bug?
Paul Reck Tue, 11/03/2009 - 14:05
Hi Ken,
it certainly sounds like it though I can't see any Bug IDs like it reported in the Bug Toolkit.
You could log a TAC case about it, but it looks like you've already discovered the solution to the problem, and that updating to at least is likely to resolve the issue.
