Upgrade reasons for PIX ver 6.3.5 to ver 8.x
Nov 2nd, 2009
i have pix 515E in failover mode with ver 6.3.5. Though i will be replacing those with ASA in next one year time, i want to know if there are reasons(security caveats, vpn compatability etc) for upgrading pix version to 8.x in the interim. I do not need to use any additional features that might come with ver 8.x.
If i have to upgrade to ver 8.x (after first upgrading to ver 7.2), do i have to re-write confiuration manually or are there tool available that converts the configuation?
Thanks in advance.
If you do not require the extra features that are in versions 7.x & 8.x then I see no real reason to upgrade. There have been a few security advisory's for the 6 train - but they were pretty much all fixed with 6.3.5 I think.
The config will be converted when if you migrate from 6 to 7, from 7 to 8 the config is 99% the same.
