Connecting CallManager to AD ?!
Nov 3rd, 2009
Hi all,
we'd like to connect our Callmanager (4.3) to our Active Directory sind we'd like the fields for telephone and fax number automatically be filled with the entries being stored in the Callmanager.
Can we as end users do this by ourself - somehow ? Or does the connection have to programmed or the Callmanager have to be enhanced with some module ?
If we can do this ourself the question is: how ?
Niclas
Jaime Valencia Tue, 11/03/2009 - 08:37
Just to add something, unless you have access to CUCM Admin via RDP or VNC into the server along with all the credentials needed for the integration into the AD and knowledge of which OUs hold the info you want, contact your admin and ask him about this. You could break the server if you have no idea.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
NiclasCpm Wed, 11/04/2009 - 01:44
Thanks to both of you.
I'll look through the HowTo. Finally - I guess - Cisco has to do it by theirself since we have a service and support contract. But nevertheless I'd like to know what has to be done. ;)
@javalenc: I have access to the CM via RDP or the server itself (console), have all needed credentials and know which OUs to pick. Eventually I should know what to do. :)
But I'm sure that this has to be done by Cisco due to our contract and the loss of guarantee in case we did anything.
I thought that there was a simple feature in CM to access the AD.
But installing any software or changing core configurations mustn't be done by us.
