QOS config....
Nov 3rd, 2009
Hi...
I am confusing while configuring qos.
This is my present scenarion,
DC ---------SP MPLS---------Branch
I have antivirus server at DC which is used for updating client at Branch.But problem is that at Branch side i have 128 Kb Link.In the morning while updating antivirus my bandwidth is choked up completely.
Is there any workaround for avoiding this kind of problem?
Overall Rating: 3 (1 ratings)
lgijssel Tue, 11/03/2009 - 02:22
  • Red, 2250 points or more
QoS will not really help you. By reducing the bandwidth for update-traffic, the sessions will likely starve before completion.
The only viable solution would be to install a local update server at the branch office.
regards,
Leo
Joseph W. Doherty Tue, 11/03/2009 - 09:32
"Is there any workaround for avoiding this kind of problem?"
There may be. Possible solutions depend on your equipment and logical topology.
For instance, if only the DC and branch exchanged traffic, and if your equipement supported it, a hiearchal policy at the DC shaping for 128 Kbps, with the subordinate policy providing the AV update traffic a minimal bandwidth guarantee might do the trick.
i.e.
policy-map shape4branch
class matchBranch
bandwidth 128
shape average 128000
service-policy branchPolicy
policy-map branchPolicy
class AV
bandwidth percent 1
class class-default
fair-queue
If other sites could also send traffic to the branch (common on MPLS clouds), then you would likely need to work with the MPLS vendor's QoS. For such, you would classify AV update to go into the least bandwidth guaranteed class. (BTW, you might still need to priorization QoS at the DC.)
arjunsawant Tue, 11/03/2009 - 19:59
Hi...
Thanx for ur reply..
But where i have to configure these command,
on DC or branch router.Because i have 20 branches which are connected to DC with same scenario and having same problem.
where should i apply this policy on IN/OUT interface and in which direction?
Joseph W. Doherty Wed, 11/04/2009 - 03:24
If the issue is only as you describe, you define the policy at the DC for output. If there is no branch-to-branch communication, you would have a class statement to match each branch (normally you match against destination block address), otherwise you just deprioritize the AV traffic into a single class and utilize your MPLS vendor's QoS model so that such traffic is also deprioritized by them as it exits the MPLS cloud.
As examples:
For first instance:
policy-map shape4branchs
class matchBranch1
bandwidth 128
class matchBranch2
bandwidth 128
class AV
bandwidth percent 1
class class-default
fair-queue
=or (2nd instance)=
class AV
bandwidth percent 1
set ip dscp ?? (value depends on MPLS vendor)
class class-default
fair-queue
